Activity Forums Panasonic Cameras P2 Transfer
  • P2 Transfer
    Posted by Patricia Stitson on February 12, 2009 at 6:11 pm
    Hi there,
    SO the camera man that I worked with did not import the footage from the p2 cards like in the tutorial by Shane Ross. He just dumped them altogether into one folder for the whole project.
    They are all QT movies and I am having a hard time figuring out how to import them into FCP through the log and transfer window. It says that they are not recognizable files. Is it because he did not include the lastclip.txt file?
    Patty
    Jeremy Garchow replied 17 years, 7 months ago 4 Members · 4 Replies
  • Noah Kadner
    February 12, 2009 at 6:29 pm
    I’d go ahead and get an MXF translator otherwise you’ll have major issues with FCP’s log and transfer. That’s Raylight or MXF4QT.
    -Noah
    Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
    Now featuring the Sony EX1 Guidebook,
    DVD Studio Pro and How to Light Interviews.
    https://www.callboxlive.com
  • Jeremy Garchow
    February 12, 2009 at 9:52 pm
    [Patricia Stitson] “They are all QT movies and I am having a hard time figuring out how to import them into FCP through the log and transfer window.”
    If they are already Quicktime movies, you simply drag them in to the project.
    Did that person include an FCP project with the footage?
    Jeremy
  • Dave Neyman
    February 13, 2009 at 7:15 am
    Like Jeremy says, if they are QT movies it sounds like he already captured the clips and they are ready to be brought into the FCP project. You would not use the Log & Transfer feature for this. Of equal concern… Where are the master files? I would be sure to get those from him as well.
    If he has given you the master files and simply ommited the lastclip.txt file then you need to do as Noah suggests and use Raylight to convert them.
  • Jeremy Garchow
    February 13, 2009 at 2:49 pm
    [Dave Neyman] “If he has given you the master files and simply ommited the lastclip.txt file then you need to do as Noah suggests and use Raylight to convert them.”
    Log and transfer works without the lastclip.txt.
    Jeremy
