Activity Forums Apple Final Cut Pro Legacy P2 to final cut pro issues
  • P2 to final cut pro issues
    Posted by Sophie Kostrowska on February 27, 2011 at 3:58 am
    I am editing on fcp 5 and have imported some footage from P2 shot at PAL 1440×1080 HD 25fps and dslr 1920×1080 HD 25fps.
    Firstly the audio/video settings do not seem to have a dvcpro anamorphic 25 setting, am i doing something wrong?
    secondly do you have advice on getting my footage to edit seemlessly together…as i have learnt my lesson about getting the perfect settings the hard way in the past
    Thankyou 🙂
    x
    Sophie Kostrowska replied 15 years, 7 months ago 2 Members · 2 Replies
  • Chris Tompkins
    February 27, 2011 at 1:48 pm
    Your footage is HD, you should edit in HD.
    Drop a clip from the P2 footage into a new emty sequence and let FCP set the sequence settings for you.
    What did you bring the DSLR footage in as?
    Chris Tompkins
    Video Atlanta LLC
  • Sophie Kostrowska
    February 27, 2011 at 2:15 pm
    well basically i just did file > import p2 and for dslr i did file > import straight from my canon folder
    only thing is the setting fcp had was dv-pal which i didnt think did HD? will it affect the quality by export time?
    Sophie Confused
    x
