Activity Forums Panasonic Cameras P2 Seminar in Burbank CA Jun 13 , questions?
  • P2 Seminar in Burbank CA Jun 13 , questions?
    Posted by Javier Ramirez on June 8, 2007 at 8:09 pm
    Do you currently own a Panasonic P2 Camera or have worked with one? If not, are you interested in the technology but still have a few questions about the camera and the HD format?
    Studio Exchange has teamed up with Panasonic to give you the answers! You and your colleagues are cordially invited to attend a FREE Panasonic P2 HD Clinic on Wednesday, June 13th.
    The new P2 HD cameras will be available for you to check out and technicians will be there to answer all of your P2 concerns. We
    Barry Green replied 19 years, 3 months ago 3 Members · 2 Replies
  • Arthur Luhn
    June 8, 2007 at 10:06 pm
    With 16mb cards already available and 32mb around the corner, is there any chance the P2 guys are going to go 1080p on the HVX? Right now the 720p is where the HVX-200 is at its best with all those frame rates/shutter speed options, but will the same also be true for a 1080p function someday?
    Thanks..
  • Barry Green
    June 8, 2007 at 11:05 pm
    The HVX200 already does 1080p. But no there’s not likely going to be variable frame rates in 1080p, the DVCPRO-HD 1080 codec doesn’t really provide for that.
    Unless you go with Hydra, which will let you get variable frame rates in 1080p, but that’s not using P2, that’s a direct cable connection to a computer.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
