Activity › Forums › Panasonic Cameras › P2 Problems importing clips from HVX200 after installing software
  • P2 Problems importing clips from HVX200 after installing software
    Posted by Tristan Wira on November 23, 2008 at 2:55 am
    Hi, how you doing? My name is Tristan and I seem to have a problem when trying to import some clips from the panasonic hvx200 with the P2.
    I’ve installed the latest driver, then the p2 viewer and then the p2 content manager.
    I’ve follewed the manual. after specifying the INGEST i wanted to register the clips in P2. BUT THE CLIPS DONT SHOW UP where they should show up.
    Does anybody know what i’ve done wrong?
    Thanks in advance for the effort.
    grt, Tristan
    Can Uzer replied 16 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tristan Wira
    November 23, 2008 at 10:19 am
    a slight correction in my post before this one
    i found out that i forgot one driver to install in stated me to use a usb 2.0 to install
    after connecting the usb 2.0 to the hvx200 and the pc, i clicked on install and still prompts me for connecting the usb 2.0
    does anybody know what’s wrong?
    thanks again
  • Shane Ross
    November 23, 2008 at 11:46 pm
    What computer are you using? How are you connecting the P2 cards to the computer? Camera via USB? Firewire? Is the camera set up to be seen as a 1394 Device? USB Device?
    Does the card mount on the desktop?>
    Shane
  • Tristan Wira
    November 26, 2008 at 11:18 am
    hi shane,
    thnx for responding,
    ehm i use a hp pc dual core 3,54 gb ddr, windows xp service pack 3
    and adobe premiere pro cs3
    in the meanwhile i’ve found a lot of info bout importing p2 cards footage. I got somebody to help me out, i didn’t notice the button on the left side of the panasonic to be recognized as a 1394 device.
    as i mentioned i got somebody to help me out, but that person has a MAC computer and via his MAC, he helped me store the footage via p2 content management system directly on my external hard drive,without going through a FCP
    right now i have a bunch of MXF files mixed, so i have a lot to sort out. that’s no biggie but what need to know right now
    is: HOW TO IMPORT THESE MXF FILES INTO PREMIERE PRO CS3..?
    i understand that I need to convert it..can you tell me with what program i can convert the files (pls an affordable one and or reasonable quality)
    and to what file extension i need to convert the mxf files? to .mov or something else?
    cuz the footage consists of video, audio, proxy elements. when i want to convert do i just select the video footage or do i have to add the right audio with the right video footage first before inputting in a converter program?
    i know a lot of questions…so i hope you can help. MUCH APPRECIATED!!!
    tnx in advance
  • Shane Ross
    November 26, 2008 at 2:20 pm
    Ah….CS3. Not my area of expertise. Might have to wait for someone who does know CS3, or post in the Adobe forums here at the Cow.
    Shane
  • Tristan Wira
    November 27, 2008 at 12:23 pm
    okey too bad…
    tnx anyways for the effort
    grts
  • David Keslick
    December 1, 2008 at 10:38 pm
    You might look into Raylight for windows. Once installed it allows you to drag .mxf files directly into your Premiere project. You can also use it to author P2 cards. http://www.dvfilm.com/raylight
  • Can Uzer
    December 25, 2009 at 3:43 pm
    Hi there,
    I just bought this Panasonic AG-HVX203AMC and i filmed with tape mode and p2 mode.
    I can capture the dv tape via firewire 1394 on my mac version 10.5.8 but when i change the mode to P2 i can see the clips on the camera vcr in the slot but nothing appears on my desktop and i can export anything chosing the FCP p2 panasonic import.
    How can i manage my mac to see the p2 card via firewire or usb?
    Please help.
    Regards
