Activity Forums Apple Final Cut Pro Legacy P2-Preview unsupported from archive drive
  • P2-Preview unsupported from archive drive
    Posted by Jonathan Skurnik on October 23, 2008 at 6:17 pm
    Last year, Marc posted this question and no one responded. Now I’m having the same problem. Does anyone know the answer to this problem:
    I have Panasonic’s P2 store drive and an external drive that I’m using to archive all my P2 footage on.
    When I’m in FCP and I use the “Log and Transfer” feature to view and copy clips to the scratch disk *from* the P2 drive, the clips all show up nice and neat and are viewable in the preview window. However, when I’ve copied those exact same clips (contents folder and lastclip.txt) to my archiving drive, and I try to log and transfer, the clips show up perfectly, but FCP won’t let me see video previews, telling me “preview unsupported for this format”.
    The files are the exact same ones I just saw with no problem from the P2 drive — merely now on another drive — any explanation as to why I’d see this?
    Mark Fanjoy replied 16 years, 6 months ago 6 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    October 23, 2008 at 6:39 pm
    What format of p2 from what camera?
    How is oyu external drive formatted? Fat32 by chance? If you are on a Mac, you need to be formatted for OSX extended.
    Jeremy
  • Jonathan Skurnik
    October 23, 2008 at 7:02 pm
    IT’s the standard P2 format from the HVX200. Drive is os extended. Lots of pros are having this problem, even Shane Ross a few times. It must be a bug.
  • Jeremy Garchow
    October 23, 2008 at 8:17 pm
    [Jonathan Skurnik] “It must be a bug.”
    Yeah, must be. I have never seen this error and I have transferred terrabytes of p2 by now.
    What format is the footage? I assume you’ve done the trash preferences routine?
    Have you tried reinstalling FCP? Have you tried looking at the footage in the free P2CMS?
    ALso, have you tried another hard drive?
  • Jonathan Skurnik
    October 23, 2008 at 11:20 pm
    It happens on every HD. Can you take me through the trash preferences routine, I don’t know about that.
    -J
  • Jeremy Garchow
    October 23, 2008 at 11:31 pm
    Download this:
    https://www.digitalrebellion.com/pref_man.htm
    It’s free!
    It will help trash (and also backup and restore prefs for when you need this again).
    Jeremy
  • Andres Jimenez
    July 14, 2009 at 8:40 pm
    I’ve been working with P2 for awhile myself and had no problem of the sort but I just installed a new internal hard disk and is doing the same thing, the strange thing is that if I install the same disk in another computer it appears to be no problems. Any thought?
  • Jeremy Garchow
    July 14, 2009 at 9:15 pm
    “Preview Unsupproted by this format” usually means the you have a weird symbol the name of your folder structure.
    So if your CONTENTS folder is within a folder called Folder#1, you will get this error.
    Keep folder names to words, letters and underscores.
    Jeremy
  • Andres Jimenez
    July 14, 2009 at 9:32 pm
    I checked that, but it happens to all the P2 volumes I backed up on this drive regardless of the name, any other ideas?
  • Jeremy Garchow
    July 14, 2009 at 9:50 pm
    What’s the name of the drive?
  • Malcolm Noble
    December 14, 2009 at 7:49 am
    I had the same problem but after reading this, I renamed my HD with only letters and numbers, and worked. Thanks
