Activity Forums Apple Final Cut Pro Legacy P2 Metadata Import In FCP 6
  • P2 Metadata Import In FCP 6
    Posted by Ben Cheng on July 31, 2007 at 8:00 am
    I like to seek advice on importing P2 metadata into FCP 6.
    – Does FCP 6 import the P2 metadata?
    – Where does FCP save the metadata to?
    From an article I read on Apple Partners website, (https://images.apple.com/finalcutstudio/partners/cameras.html), the metadata is saved onto the QuickTime movie, as XML format.
    Is this correct?
    – How do I view the metadata in FCP?
    – Is it possible to search the metadata in FCP?
    Any advice is greatly appreciated!
    Cheers,
    Ben Cheng
    The Media Village
    Singapore
    Ben Cheng replied 19 years, 1 month ago 2 Members · 2 Replies
  • Marcus Van bavel
    July 31, 2007 at 3:23 pm
    I don’t think FCP can do that, but Raylight for Mac ( https://dvfilm.com/raylight/mac ) version 1.06 will allow you to read P2 metadata from the quicktime player, or from Final Cut (it creates a metadata virtual slate which is viewable in FCP). Also the metadata User Clip Name and Program Name can be used to automatically rename the clips and organize them into folders, so that might cover what you need to sort clips by scene and take.
  • Ben Cheng
    August 1, 2007 at 6:12 am
    Hi Marcus,
    Thanks for your reply.
    I tested Raylight yesterday and it performed as you mentioned.
    I do have some concerns about changing the filenames, and maintaining the link between the P2 MXF and QuickTime reference movies.
    Most prob, we will stick with the original MXF filename, to reduce the strain of maintaining a database.
    Cheers,
    Ben
