Activity Forums Apple Final Cut Pro Legacy P2 Log and transfer on broadcast monitor problem
  • P2 Log and transfer on broadcast monitor problem
    Posted by Jason Richards on October 15, 2007 at 2:46 pm
    Gang, when I log and capture or edit I can see my video in my
    broadcast monitor. When I log and transfer P2 footage it does not appear on my broadcast monitor. Is there some setting that I need to adjust or is that just not an option?
    Jerry Hofmann replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 15, 2007 at 3:07 pm
    Dont’ think this is an option… Just as you cannot view a broadcast monitor during the log and capture process you can’t do the same with the log and transfer window.
    I route my analog outs to a monitor during log and capture, but don’t think there’s a way to do this with a P2 card… if the player has analog outs, that might work… but by itself, you can only go in or out thru FCP… not both at the same time.
    Jerry
