Activity Forums Media 100 P2 Import to Suite
  • P2 Import to Suite
    Posted by Frank Cann on February 9, 2010 at 3:36 pm
    I’m new to P2. Is there any tutorial out there showing proper Import to Media 100. I must be doing something wrong – my clip comes in & won’t play back and tells me bad frame.
    Matt Mullen replied 16 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Floh Peters
    February 9, 2010 at 3:43 pm
    Not really sure what you could do wrong there. What codec are they? What resolution and frame rate? Where are your media files?
  • Frank Cann
    February 9, 2010 at 4:01 pm
    By the way great job on workflow junkies.
    Very new at this.
    I shot (2) clips on the panasonic HPX300.
    AVC-1_100_1080/29.97p
    DVCPROHD_1080/59.94i
    I offloaded the clips into the Panasonic P2 Contents management software.
    I then went into M100 and attempted to import P2.
    Both clips appear to be importing correctly however – once in my bin – there is no (black) image in the thumbnail of the clip & playback tells me – bad frame as a pop up (that I can’t seem to escape with out force quitting M100.
  • Floh Peters
    February 9, 2010 at 4:11 pm
    The “bad video frame” means that the system tries to decode a file, but it gets not what it expects. So most likely it imported the files with a codec that is not supported in Media 100. AVC-Intra is right now not a codec that can be played back natively; only with a conversion e.g. via the MXF plugin from “Calibrated”.
    When you put the bin in list view, what codecs, framerates and resolutions are displayed for the files?
  • Wickham Strub
    February 9, 2010 at 4:44 pm
    Frank,
    As Floh mentioned, M100 cannot currently handle AVC-Intra “natively”.
    As for the DVCPROHD clip, however, a clue might be gained by going to:
    “Media 100 Suite” menu > Project Settings > Codecs…
    In there, under the “HD” tab, see if “DVCPro HD” is greyed out in the drop-down menus. If so, that means that a codec component that can understand DVCPro HD is not installed. If installed, the component would be found in: MacHD\Library\QuickTime.
    Most often, they get there by installing Final Cut Pro. However, there are other solutions (Flow mentioned Calibrated Software) out there in the world.
    Hope this helps more than confuses.
    ~Wick
  • Frank Cann
    February 9, 2010 at 5:57 pm
    I think you found my problem. In list mode it’s saying “Codec Not Installed dvh6”
    Now what?
    By the way – thank you so much for helping me with this – I feel so clueless
  • Floh Peters
    February 9, 2010 at 6:00 pm
    [Frank Cann] “Now what? “
    If you have FCP somewhere you can copy the DVCPro codecs from the Library->QuickTime folder to your system. If not, you could have a look at the DVCPro Decoder from Calibrated. They have a free trial version.
  • Matt Mullen
    February 11, 2010 at 5:24 pm
    Frank,
    I spoke with you on the phone. We’re you able to get the codecs?
