Activity Forums Panasonic Cameras P2 Import to FCP 5.1.2 ERRORS
  • Rustyrik
    October 12, 2006 at 1:59 am
    Finally! I actually glad someone else is experiencing this, so Apple can work on a fix, I was beginning to think I was alone. I do, however, have a bunch of clips under 30sec that have the problem, so I don’t think duration is problem if it is that wide-spread.
    Rik
  • Jay Dobek
    October 13, 2006 at 10:17 am
    I’ve had this problem as well – and yes, it started once I upgraded to FCP 5.1.2. Basically, I keep importing the clip- it normally takes about 5 attempts and it conforms to 23.98 fps.
  • Jay Dobek
    October 13, 2006 at 10:24 am
    Try this – in the P2 import widow – select the problem clip in the list. It will show up in the P2 viewer to the right. Now enter a scene name in the logging section. Then select “Add Clip to Queue.”
    Just tried it – it worked fine. But I only did this once . . .
  • Scott Tupper
    October 16, 2006 at 7:54 pm
    We are having the same issue except it does not matter what the length is as we have 7 second clips and 9 second clips that import fine. We are however having what looks like field/interlace issues on our SD monitor when viewing these 480i30p clips.
    Anyone\?
  • Scott Tupper
    October 16, 2006 at 8:26 pm
    480i30p DVCPRO50 seems to be the culprit as we just concluded testing with DVCPRO25 and no issues.
    Anyone?
  • Jan Crittenden livingston
    October 16, 2006 at 9:38 pm
    Hi everyone,
    Would you all that are having the problem identify which version of Quicktime you have loaded?
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Darenu
    October 16, 2006 at 9:45 pm
    7.1.3
    All other Apple updates are installed
  • Scott Tupper
    October 16, 2006 at 9:46 pm
    G5 Quad FCP 5.1.2 QT 7.1.3
  • Gary Adcock
    October 16, 2006 at 10:02 pm
    [Jan Crittenden Livingston] “Would you all that are having the problem identify which version of Quicktime you have loaded?”
    Jan
    I can confirm that I am also having these issues with FCP 5.1.2 and QT 7.1.3
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    October 17, 2006 at 1:45 am
    Okay, So now tell me your serial number on the camcorder.
    Jan,
    PS. Should have asked both questions before.
Page 3 of 5
