Activity Forums Panasonic Cameras P2 Import problems clips Idle
  • Michael Alberts
    January 5, 2007 at 1:37 am
    Annoying isn’t it. It would appear that the checkbox for “remove advanced pulldown and duplicate frames” check box is on by default. If your material is shot 24Pn then apparently this checkbox prevents FCP from importing the clip. If you right click on a shot in your import window and select “preferences” and uncheck that box you should be fine. Can’t find any documentation as to this checkbox needing to be unchecked, but it works none the less.
    Michael Alberts
    Ambidextrous Productions, Inc.
