Activity › Forums › Avid Media Composer › P2 import problems
  • P2 import problems
    Posted by Marianna Ellenberg on February 3, 2009 at 7:18 pm
    I am using P2 import function in avid and having huge problems. 1. Its doesnt recognize many of the clips and reads “no clips were found. Are you sure you selected a p2 card media directory?” When I specifically slected a P2 folder. I also imported the clips and sometimes half of a clip will go offline after impoorting the media.
    Any ideas why avid is not recognnizing the P2 media files?
    Thanks!!
    Marianna
    Michael Phillips replied 17 years, 7 months ago 3 Members · 2 Replies
  • David Braswell
    February 3, 2009 at 8:32 pm
    Import problems are covered pretty heavily here and on Avid’s own forums, but in general:
    1-Make sure only ONE bin and NO sequences are open.
    2-Make sure you point to the top level folder holding your P2 media. In other words you should see “CONTENTS” folder after you select.
  • Michael Phillips
    February 4, 2009 at 3:18 am
    Have you watched the videos on http://www.avid.com/p2
    Michael
    Michael Phillips
