Activity Forums Apple Final Cut Pro Legacy P2 import problem
  • P2 import problem
    Posted by Rikard Lassenius on June 1, 2007 at 1:29 pm
    hi, i’m having troubles importing some P2 footage.
    we shot a bunch of stuff with the Panasonic HVX200 in full HD 25p on a FireStore hard drive. dumped the stuff onto a backup drive and started importing it from there. much to our chock a big precentage of the shots can’t be imported. when you add them to the cue, nothing happens, a warning sign appears which gives you the option to retry or remove.
    funny enough (actyually not very funny) all clips that can’t be im ported are less than 20 seconds long. could that be the reason?
    ((( Read about the bug which can be fixed by turning off the ‘remove duplicate frames’ option )))
    i’m running a intel macpro with fcp 5.1.4
    Rikard Lassenius replied 19 years, 3 months ago 2 Members · 2 Replies
