Activity Forums Apple Final Cut Pro Legacy P2 HD VIDEO WOES
  • P2 HD VIDEO WOES
    Posted by Matt Rinaldo on July 9, 2008 at 11:47 pm
    We shot a commercial on i believe the Panasonic AJ-HPX3000. In 1080i and at 24P. We are having slight storbeing problems with our transferred video. when the talent moves a bit there is sometimes a slightly noticeable jitter in the video?
    Here are my questions:
    When you transfer P2 footage into Final Cut do you have to select the codec that you want the footage to be brought into Final Cut as? Like a capture setting or easy setup? I could not find this.
    If the footage was shot in 24p why is the frame rate of your clips 29.97 in the bin?
    We brought one of our clips into the timeline and the “your clip settings do not match your sequence setting, do you want to change your sequence settings to match your clip setting”s box came open. we clicked yes. could that have been a mistake, it dont think so but you never know
    Andrew Kasch replied 16 years, 7 months ago 5 Members · 14 Replies
  • 14 Replies
  • Shane Ross
    July 9, 2008 at 11:51 pm
    [matt rinaldo]
    When you transfer P2 footage into Final Cut do you have to select the codec that you want the footage to be brought into Final Cut as? Like a capture setting or easy setup?”
    Nope. FCP will import the footage in the exact same codec as it was shot. You cannot convert this footage with FCP. All Log and Transfer does is marry audio and video inside a quicktime wrapper.
    Did you shoot AVCIntra or DVCPRO HD?
    [matt rinaldo] “If the footage was shot in 24p why is the frame rate of your clips 29.97 in the bin?”
    It might have been shot…OH! 1080i 24PA? Was it shot that way? If so, you need to remove the pulldown when importing. You do this by going into the preferences in the Log and Transfer window.
    This only works if you shot 1080i 24pa. If you shot 1080i 24p, then your footage will be 24p running at 29.97. If you need to get it to 23.98, then you might need to use Cinema Tools to reverse telecine the footage. That option is also available in FCP in the TOOLS menu.
    Shane
  • Walter Biscardi
    July 9, 2008 at 11:52 pm
    [matt rinaldo] “In 1080i and at 24P”
    1080i and 24p are two completely different things.
    1080i is interlaced video
    24p is progressive video
    what did you actually shoot?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Matt Rinaldo
    July 9, 2008 at 11:58 pm
    we shot at 24 frames per second in 1080i
  • Matt Rinaldo
    July 9, 2008 at 11:59 pm
    Thanks for the response.
    We shot the footage in DVCPRO HD an it was 24P not 24PA. It is weird because the frame rate for each of the clips is 29.97? Could explain the everse telecine thing in final cut
  • Shane Ross
    July 10, 2008 at 12:03 am
    [matt rinaldo] “It is weird because the frame rate for each of the clips is 29.97?”
    Not weird at all. 1080i 24p runs at 29.97…it just has the 24p cadence.
    Shane
  • Jeremy Garchow
    July 10, 2008 at 12:17 am
    Matt, I could be wrong, but I believe that camera shoots 23.98 PSF (essentially 24pN) in AVCINtra mode only. In DVCPro HD, it’s 24p with opulldown bringing the footage to 29.97.
    Take all of your orig quicktime clips (the ones right out of the Capture Scratch) and run a reverse telecine on them through COmpressor. The process is damn near automatic and painless as long as you set the frame size and codec properly.
    Jeremy
  • Matt Rinaldo
    July 10, 2008 at 1:29 am
    That would explain the 29.97 frame rate. We are all trying to lear as we go wit this camera. Thanks for the advice. I will pass it along and test out a clip in compressor tomorrow morning. Thanks again
  • Matt Rinaldo
    July 10, 2008 at 1:42 am
    Thanks a bunch you all have been very helpful. The camera actually just got a AVCINtra installed. We did not use it but apparently we should have. I am going to run a test in CO and see if that fixes your jitter problem.
    Take Care
    Matt
  • Jeremy Garchow
    July 10, 2008 at 1:47 am
    [matt rinaldo] “We did not use it but apparently we should have.”
    Oh man, if you have the choice, shoot AVCIntra. It’s 10bit native full raster recording and looks freaking great. The footage gets transcoded to ProRes in the log and capture process as AVCIntra seems to not be ready for real time editing. The process takes a bit longer to ingest than DVCPro HD, but it is well worth the wait. Panasonic did a very nice job with AVCIntra.
    Jeremy
  • Matt Rinaldo
    July 10, 2008 at 1:49 am
    Hey
    I was just looking around n compressor and could not find the reverse telecine that you were talking about. Is this a format? I will try to google it, but please let me know
    thanks again
    matt
