Activity › Forums › Panasonic Cameras › P2 Formats
  • David S.
    May 3, 2007 at 2:58 pm
    720.24pN does run at normal speeds.
    You didn’t mention which NLE you use, but we generally shoot to cards at 24pn and drop is into a FCP 720/24p sequence and edit.
  • Russell Lasson
    May 3, 2007 at 4:41 pm
    You could have had it set up for over or under cranking on accident. Is everything in slow motion?
    -Russ
  • David S.
    May 3, 2007 at 4:54 pm
    Was it 720/24p over 60 in the film mode?
  • Freeroad
    May 4, 2007 at 11:54 am
    We shot at 720p 30PN @24fps on accident.
    So everything is a bit Charlie Chaplinesque.
    Any ideas how to bring things back to normal speed?
  • Russell Lasson
    May 4, 2007 at 4:33 pm
    You could try bringing a clip into Cinema Tools and and conforming it to 23.98. This won’t take out any frames, it will just retime the 30 frames a second to take place over 24 frames a second instead. So your clip will get longer.
    I’m not sure how this will effect your audio though. What ever you do, make a copy of your footage before you start playing around with it. Give this a try though.
    -Russ
