Activity Forums Panasonic Cameras P2 footage not going into canvas at same resolution
  • P2 footage not going into canvas at same resolution
    Posted by Arthur Luhn on March 7, 2007 at 5:16 pm
    Importing P2 footage in 720p24, looks beautiful in viewer, but when transferring to Canvas, it looks like DV footage. I have been playing around with Sequence settings- changing frame size to HD 960 x 720, etc. this doesn’t do anything. Should it be uncompressed??
    Help!
    Arthur
    Shane Ross replied 19 years, 6 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    March 7, 2007 at 6:05 pm
    No, choose the DVCPro HD 720p24 easy setup, MAKE A NEW SEQUENCE and then put your clips in. ALso, what are you watching? Your computer monitor? You need to get yourself a proper HD monitor to properly see the full resolution. FCP is knocking down the resolution so it’ll fit in the canvas window for preview purposes only. If you have a capture card and an HD monitor, you could see it in it’s full rez glory.
    Jeremy
  • Arthur Luhn
    March 7, 2007 at 7:45 pm
    Yes I have the HD cinema monitor from Apple.
    I followed instructions and it seems to work fine now. I also Sequence>settings and loaded sequence preset 720p24.
    I guess the key is to open a new sequence AFTER the easy setup has been established??
  • Shane Ross
    March 7, 2007 at 7:47 pm
    That is the key…
    Shane
    Littlefrog Post
    http://www.lfhd.net
