Activity Forums Panasonic Cameras P2 files play in Transfer window but won’t import
  • P2 files play in Transfer window but won’t import
    Posted by Steve Hobbs on January 19, 2011 at 11:20 am
    Having a problem with P2 files not importing. There are several P2s from same cards that will import but 3 files refuse to cooperate. They will play in Transfer window but will not import. Using FCP 7.0.3, tried it on 3 FCP systems. P2s reside on a G-RAID 4TB and a portion on the files can not be copied to another drive (getting error code 36: “The finder cannot complete the operation because some of the data in could not be read or written”). Any ideas on how to get these files imported/repaired? Thanks.
    Shane Ross replied 15 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    January 19, 2011 at 8:27 pm
    Everything else imports BUT these clips? Might indicate some issue with the clips. You can try HD LOG, it has a REPAIR P2 function. Or, you can get Calibrated or MXF4Mac and bring in the footage without transcoding, just bring in the raw MXF files and work off those.
    Shane
