Activity › Forums › Adobe Premiere Pro › P2 files in offline edit
  • P2 files in offline edit
    Posted by Gabriel Sanchez on February 20, 2012 at 9:13 am
    Hi. I´ve been editing a 720 25p sequence with low res version of 720 25p files from my Panasonic HVX200. This low res files are avi DV 576i with 2 stereo channels. When i disconnect them and try to reconnect to the original 720 25p files premiere cannot do this because the original files have 4 mono channels.
    Any tip for this workflow? How could i do an offline edit with low res versions of mxf files being sure i will be able to connect them to the original ones at the end of edit?
    Regards.
    PP CS5 in W7 64
    i7 920
    2 Tb Raid0 – media
    500 gb OS
    1 Tb hard disk – renders and exports
    GF GXT460
    Paul Sourice replied 14 years, 1 month ago 3 Members · 5 Replies
  • John-michael Seng-wheeler
    February 22, 2012 at 4:09 pm
    [Gabriel Sanchez] ” premiere cannot do this because the original files have 4 mono channels.”
    What do you mean by “cannot”? Is premiere giving you an error message?
    Why are you editing this offline anyway? Your computer would appear more then capable of an On-line edit.
  • Gabriel Sanchez
    February 22, 2012 at 8:54 pm
    Hi John, thanks for the reply.
    Yes, Premiere says something like can´t do that because the relinked files have different audio tracks than the offline ones.
    Of course, my computer can handle an online edit with p2 files with no problem, but I´m doing this only for my classes, as i´m a video editing teacher, and a student asked me for the way of editing hd files with a less powerful computer. I´m trying to make a proyect for him to understand this workflow.
    The question is not really very important, as the student´s footage is in AVCHD format with (i guess) two stereo tracks, but just wondering how to do it if the footage would be from a p2 camera like mine.
    Regards.
    February 22, 2012 at 9:14 pm
    I’ve swapped P2 footage for stuff with only 2 tracks, though not the other way around like you’re trying to do.
    How are you swapping the files? Are you useing replace media or making the files offline and then linking to the new files? Which ever you’re useing you should try the other.
    The real problem is that premiere isn’t really made for an offline/online workflow… adobe’s philosophy is online all the way. AVID would do this best. I aggre though, his AVCHD footage sould work much better. P2 is just plain funny to work with sometimes.
  • Gabriel Sanchez
    February 22, 2012 at 9:39 pm
    Hi John, thanks for the trick.
    I´m doing it making the files offline and then linking to the new files, so i´ll try the other way.
    Regards!
  • Paul Sourice
    August 14, 2012 at 3:10 pm
    ok it’s been six month, but I am having trouble with low res offline/online media for editing on laptop.
    I’ve tried this way,
    – import online p2 1080 in new ppro cs6 project,
    – import same file in media encoder,
    – transcode to something lighter, like h264 mp4,
    – import low res into new bin in ppro,
    – do the edit with low res media
    – unlink, low res média and trying to relink them to original footage.
    The last step is working but not with batch treatment (unlike with fcp), I guess it is because ppro consider the extension *.mp4 or *.mxf as part of the name (so not the same).
    I am looking for automatic batch recapture of online hd footage because my project is over 20 hours of 1080p2 and thousands of clips, I can’t do it one by one!
    Isn’t there a way to send like an EDL to média encoder so that it does the onlining jobs using edl & metadatas?
    If anyone has an idea I would bless it,
    thx
    Paul
