Activity › Forums › Apple Final Cut Pro Legacy › P2 drivers
P2 drivers
Posted by Ashley Mcpike on August 12, 2009 at 6:57 pmI have been trying to find the answer to this question all day so PLEASE help me!!! Okay so I shoot footage on a 16 GB P2 card using a HDX 500 Panasonic camera, I uploaded the footage to an external hard drive using a duel adapter through my MacBook Pro. I created a sequence within Final Cut and everything ran smoothly, but when I try and open up the sequence on my external hard drive using my desktop Mac G5 you cannot see the video its only a gray screen, the folder and clips are present but you just can’t actually see or listen to the footage, but the log and transfer option works fine, but I don’t want to have to ingest the footage twice. I tried uploading a P2 driver, but that didn’t work either. Do I have to do something special with the P2 driver to make it work? Is there a folder I have to add it too or does it work on its own? PLEASE HELP!!!
Ashley
Andrew Johnstone replied 14 years, 6 months ago 9 Members · 16 Replies -
Aaron Smith
August 12, 2009 at 7:29 pmdid you download the drivers from the panasonic site?
https://panasonic.sixbullets.net/also, can you open up your files from your finder in quicktime? seems like something isn’t updated correctly.
Ashley Mcpike
August 12, 2009 at 7:47 pmyes i downloaded the p2 driver from that website, I download the third option the one for macs then I installed all the ones that I could within the three folders and the one outside of the folder, I restarted my computer and nothing changed. Did I do something wrong with the process? Do I have to add the files to a FCP folders? And no I cannot view the P2 card MXF files in quicktime, its says its not a movie file. What do you suggest?
Tom Brooks
August 12, 2009 at 7:59 pmYour posts are unclear on this point: Have you done log and transfer or have you only copied P2 folders to the external drive? You must have special plugins to allow FCP to edit MXF files natively. Without those plugins, you must do Log and Transfer at some point to convert P2 data to Quicktime files.
Final Cut Pro 6.0.5, Mac OS-X 10.5.6, Quicktime 7.6, Adobe Prod Prem CS4, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2. Also MBP 17″ Core 2 Duo 2.5, 4GB, GeForce 8600M GT 512MB.
Shane Ross
August 12, 2009 at 7:59 pm#48 – Cannot view DVCPRO HD or HDV or ProRes on my computer.
Shane’s Stock Answer #48 – Cannot view DVCPRO HD, HDV or ProRes QT files on your computer.
The DVCPRO HD, HDV and ProRes codecs only comes with FCP. If your computer does not have FCP installed, it cannot view these quicktime files. It doesn’t matter if it is a Mac or PC, without FCP installed, you cannot view these files.
If you need to view ProRes material, you can download the ProRes decoder (mac and windows compatible) for ProRes
https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows.
https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Mac
If your footage was captured as DVCRO HD you can buy the Calibrated DVCPRO HD decoder:
https://www.calibratedsoftware.com/QDVCProHD.asp
HDV, XDCAM? Calibrated has you covered too:
https://www.calibratedsoftware.com/QXD.asp
If you have MXF files from a P2 camera and you need to view the footage on a computer without FCP, you can download P2CMS from Panasonic:
https://www.panasonic.com/business/provideo/p2-hd/downloads-and-updates.asp
Or you need the other party to compress the footage into a format your computer can play, like H.264.
Shane
Read my blog, Little Frog in High Def -
Ashley Mcpike
August 12, 2009 at 8:05 pmI have only dragged and drop all the contents folders and .txt file to the external hard drive, I was trying to avoid the process of having to got through the log and transfer process. I thought that is what the driver was for, to avoid having to log and transfer the data. My laptop views the footage fine without having to log and transfer all I have to do is import it from the external hard drive. But my desktop is the one that can’t import, it only allows me to log and transfer. I tried the driver option, but I can’t get it to work, but I might be doing this wrong. Is there a step by step process of how to download the driver and which one to choose for my G5
John Fishback
August 12, 2009 at 8:11 pmIn FCP go to Log & Transfer in the File menu. Click on the Add Folder icon in the upper left of the L&T window. Navigate to your external drive and select the folders that contain the Contents folder and Lastclip file from each P2 card. All your clips should open in L&T (on the ledt). When you select each clip, you can play it on the right. You can set in & out points, select how many audio tracks you want, and name the clip. Click “Add Clip to Queue” to transfer the clip to your scratch drive. Now, whrn you look in the FCP browser, you’ll see the clip. FCP has transferred the MXF files from your external drive and wrapped them as a Quicktimes. If you look at your scratch drive you’ll see the QT file there.
A note: Archive the MXF files. DO NOT TRASH THEM. They are your camera masters.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ashley Mcpike
August 12, 2009 at 8:14 pmI know how to do the log and transfer process I just want to know what plug-in I need for my FCP to read the .MXF files and to avoid doing the log and transfer process.
Ashley Mcpike
August 12, 2009 at 8:31 pmI already have the P2 card footage ingested on my laptop computers, but I don’t want to have to log and transfer the footage for every other computer. What plug-in will solve this problem? I have a Mac G5 desktop what would be the best plug-in/driver to use? Once I download the software do I have to add the driver to the FCP plug-in folder?
John Fishback
August 12, 2009 at 9:15 pmI’m not sure what you want to do, but if it’s to use the transferred QTs from one computer on another computer, copy the qts to the other computer, then simply Import them to FCP. If you want to use the MXFs directly and avoid L&T check out Raylight for Mac https://dvfilmstore.com/raylight-for-mac.html, MXF4MAC https://mxf4mac.com/ or Calibrated Software https://www.calibratedsoftware.com/MXFImport_Mac.asp.
John
Aaron Smith
August 12, 2009 at 9:15 pmoh i thought you had already done the log and transfer. final cut needs to transcode the mxf files to quicktime files so it can use them. log and transfer has to be done.
