Activity › Forums › Panasonic Cameras › P2 clips only exported from FCP 5.1 imported into FCP 5.0.1?
  • P2 clips only exported from FCP 5.1 imported into FCP 5.0.1?
    Posted by Michael Mattioli on April 18, 2007 at 12:46 am
    Does anyone know if I can import P2 clips (720 30p) into FCP 5.1, then export the clips as Quicktime HD (or other format), then import those clips into FCP 5.0.1 and then build my timeline? My first P2 project, and I need to use this workaround if possible…
    Just read about needing 5.0.4 update – will it work otherwise?
    Michael Mattioli replied 19 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    April 18, 2007 at 7:32 pm
    YOu shouldn’t have to export the clips. Import the clips from P2. Copy the resulting quicktime files to another drive. OPen FCP 5.0.4 on the other machine, import all the clips on the copied drive.
    Jeremy
  • Michael Mattioli
    April 19, 2007 at 2:41 pm
    thanks Jeremy, it worked. 🙂
