Activity Forums Apple Final Cut Pro Legacy P2 choppy footage half blue circle
  • P2 choppy footage half blue circle
    Posted by James Brown on May 21, 2009 at 5:44 pm
    I am importing P2 footage and sometime I get a half blue circle once imported. When I drop the footage into the timeline it plays back choppy and sound is not sync’ed.
    I tried reimporting. Does not happen all the time so not sure what is causing the problem or how to fix it.
    I have tried looking on other forums and have found people with the same problem but no solution yet.
    I am using FCP5 but since this is an intermitent problem I am at a loss.
    James Brown replied 17 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 21, 2009 at 6:17 pm
    [James Brown] “I am importing P2 footage and sometime I get a half blue circle once imported. “
    A half blue circle usually means you have marked an in and out in the log and transfer window.
    [James Brown] “When I drop the footage into the timeline it plays back choppy and sound is not sync’ed. “
    What format and frame rate? How are you monitoring? Is it out if sync in Quicktime too?
  • James Brown
    June 4, 2009 at 7:52 pm
    I import multiple clips at a time. The ones with the half blue circle are choppy but the other clips are fine. So I have not changed settings. for example if I have five takes imported on same camera setting and same FCP settings one of them might have a half blue circle and play back choppy. The others are fine.
    I was shooting this week and just got back and have the same problem although this time is was only two clips out of 23.
