Activity Forums Panasonic Cameras P vs PN
  • Bo Skelmose
    December 26, 2008 at 11:56 am
    When I am in 720 PN I cannot use the DS gain. Maybe it has something to do with the Cine/videomode reffered to in this thread. Where do i switch between the two modes?
    -think i found it in paint/gamma but maybe its because i have a 2100 – that i cannot find any video mode
  • David Coleman
    January 2, 2009 at 5:01 pm
    I know it will seem nit-picky to you, but there is no such thing as 720 NTSC or PAL. NTSC refers to standard definition only, so using it to describe whether you’re shooting for a 60 Hz electrical system (North America) or 50 Hz (Europe) can be confusing.
  • Jeremy Garchow
    January 2, 2009 at 7:53 pm
    [David Coleman] “but there is no such thing as 720 NTSC or PAL. NTSC refers to standard definition only, so using it to describe whether you’re shooting for a 60 Hz electrical system (North America) or 50 Hz (Europe) can be confusing. “
    Absolutely correct. I find it’s easier to refer to the NTSC/PAL based frame rates of 60 or 50 Hz. I guess it’s just ingrained in me.
    [Bo Skelmose] “When I am in 720 PN I cannot use the DS gain. Maybe it has something to do with the Cine/videomode reffered to in this thread. Where do i switch between the two modes? “
    I do not believe the 2100 has video or cinema mode. The 2000 doesn’t, so I imagine the 2100 doesn’t as well.
    Jeremy
  • Bo Skelmose
    January 10, 2009 at 7:00 am
    Ok – no such switch on the 2100 – maybe the 2100 just will not do DS gain in 720P – I just thougt I used it before in a HD project.
  • Jeremy Garchow
    January 10, 2009 at 5:52 pm
    Bo, I will have to check this out on Monday.
    Jeremy
  • Dave Presley
    January 12, 2009 at 2:39 am
    why would one choose to shoot in the 24P mode if you get longer record times AND superior quality shooting 24PN?
  • Emre Tufekci s.o.a.
    January 12, 2009 at 2:50 am
    Depending on your workflow, not all systems will mix 24PN with other formats. If you have an AVID you cannot use 24PN with 60i content without converting it first. FCP will handle both on the same timeline but you have to render at a certain point.
    Emre Tufekci
    http://www.productionpit.com
  • Kyle Omlor
    January 14, 2009 at 4:10 pm
    Is there a way to shoot in 1080 at 60 frames a second. I haven’t figured that out yet
  • Jeremy Garchow
    January 15, 2009 at 12:08 am
    No 1080p60 dual link or 3gb SDI workflows are reserved for very very high end cameras.
Page 2 of 2
