Activity Forums Apple Final Cut Pro Legacy Oy Vey. Why me? Another sweet FCP bug, produced by JeremyG.
  • Oy Vey. Why me? Another sweet FCP bug, produced by JeremyG.
    Posted by Jeremy Garchow on December 10, 2007 at 6:12 pm
    Alight. Using the latest ‘greatest’ FCP 6.0.2, QT 7.3, OSX.4.11. Sound familiar?
    Using ProRes HQ material (in both 720p23.98 and 1080i29.97).
    If you take a coupla three ProRes clips, scale them down, composite them into a three up split screen, change their speed (to say 50%), then render the whole timeline at once (render-all), everything renders wrong. Some clips become full screen, some clips become still frames, some clips render just fine. Awesome…right? Okay, maybe not.
    The workaround? Render in pieces. I render for a minute, then hit cancel, render for a minute then hit cancel, render for a minute then hit cancel. Then and only then will the renders show up correctly. Why? I have no effing clue. Also, changing the sequence to 10bit uncompressed seems to fix it as well.
    This only seems to happen on material with speed changes in a ProResHQ timeline, if there’s no speed changes, everything renders properly.
    Can anyone reproduce this or has my system gone haywire? I have not tried other codecs, but I can get it to constantly repeat. Maybe it’s a Quicktime thing, maybe a ProRes thing, maybe it’s a Kona thing. Maybe I am just imagining this whole thing and I need more coffee to bring me back to reality. What do you all think?
    More tests coming and I will update as I know more.
    Jeremy
    Rafael Amador replied 18 years, 9 months ago 5 Members · 21 Replies
  • 21 Replies
  • Jeremy Garchow
    December 10, 2007 at 6:32 pm
    Well, easy thing’s first. Uninstalled and reinstall Kona drivers, and the problem now went away.
  • Jeremy Garchow
    December 10, 2007 at 6:49 pm
    Just kidding. The problem is now back. I am a little lost on this one.
    Jeremy
  • Colleen Kessler
    December 10, 2007 at 7:27 pm
    Have you tried this in a non HQ sequence? to see if it’s really the HQ codec? I’d be interested to know, we work in Pro Res 1080i 29.97 (non HQ) and have never seen this problem.
    Coll
  • Jeremy Garchow
    December 10, 2007 at 7:30 pm
    I will try. Do you have scaled and retimed footage?
    Jeremy
  • Jeremy Garchow
    December 10, 2007 at 7:39 pm
    It happens with ProRes sequence as well as HQ. I have been able to repeat this across three machines now. It’s not a KOna thing, it’s an FCP thing at this point.
    Jeremy
  • Shane Ross
    Speed changes…the BANE of Apple and FCP. There are many bugs when it comes to speed changes. They all stem from the fact that Media Management and speed changes STINK!
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Jeremy Garchow
    December 10, 2007 at 7:46 pm
    Oh yeah, I understand that, but I have never seen them render this wrong before. I have seen them not media manage properly, but this rendering thing is weird.
    i wonder if it has to be with VBR nature of ProRes? I don’t know.
    Submitting feedback soon.
  • Jeremy Garchow
    December 10, 2007 at 8:01 pm
    Alright, more testing and it is not limited to ProRes or HQ. 10 bit uncompressed also messes up. This is so weird.
  • Shane Ross
    December 10, 2007 at 9:08 pm
    Try this…
    Can you use the render manger to clear the renders and try rendering again? And try manually deleting the constant frames folder (that mysterious thing inside the render folder).
    I can’t reproduce this myself…
    (bored, nothing to do…)
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    December 10, 2007 at 9:12 pm
    Definitely deleted render files before (even rendered to a different media drive altogether). I will try constant frames. Since it happens across three machines, I am beginning to lose faith that it’s my main desktop machine that’s busted. It seems to be more a systemic FCP issue.
    How long is your timeline and is your footage ProRes captured?
    Jeremy
Page 1 of 3
