Activity › Forums › Adobe After Effects › Overlaying onto video?
  • Overlaying onto video?
    Posted by Zeke Meginsky on February 14, 2012 at 2:37 pm
    Hi, this is definitely a newbie question. How do I make an animation that I can bring into Final Cut Pro, and it will go in front of the video that already exists? Meaning, I don’t want a black background. I only want the animation itself to be brought in, and have already existing footage (in FCP) to be behind it.
    Do I have to bring the video itself into AE? I didn’t think so.. is there an easier way to do this?
    Zeke Meginsky replied 14 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    February 14, 2012 at 2:52 pm
    I’m not sure what the codecs one whould choose for FCP, but what you want to do is render out your animation with an alpha channel(if your comp has transparency). Ctrl+Shift+/ (Windows) or Command+Shift+/ (Mac OS) is the command to add a composition to the render queue.
    Check out the rendering tutorial from Andrew Kramer:
    https://www.videocopilot.net/basic/#10
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Zeke Meginsky
    February 15, 2012 at 2:25 pm
    Thanks so much for the help guys!!!!
