Activity › Forums › Adobe Premiere Pro › Overlay Problem
  • Sameer Shrivastava
    October 31, 2005 at 12:12 pm
    You have to use aftere ffects to create the correct alpha and then import to premierepro or any other editing/compositing software. You need to work similarly on afx just on one frame and press “ctrl alt s” to save that frame as photoshop 32 bit file with alpha. I dont think so photshop can create the required alpha.
    Sameer Shrivastava
  • William
    November 2, 2005 at 1:40 pm
    Thanks Sameer
    Luckily I found a similar video clip that I used in the defective one’s place. Nevertheless, I am going to try your suggestion in After Effects for the possibility of future problems.
    Again, Thanks
