Activity › Forums › Storage & Archiving › Overall Computer Set-Up // RAID // Adobe Premiere
  • Overall Computer Set-Up // RAID // Adobe Premiere
    Posted by James Kees on August 4, 2015 at 8:12 am
    Hello,
    I’m brand new to the forums so please forgive me if I’ve misfiled this or done anything incorrect. I was curious what you guys would think of my current computer set up and if you thought I should change anything, thank you.
    Here is my current set up:
    Mac Pro 1,1
    2 x 2.66 GHz Dual-Core Intel Xeon (Quad Core)
    OS X 10.9.3 Mavericks
    13 GB of RAM
    (Or it should be, it only registers some. I’m working on that problem)
    NVIDIA GeForce GTX 650 Ti 2048 MB
    [specs here: https://www.everymac.com/systems/apple/mac_pro/specs/mac-pro-quad-2.66-specs.html%5D
    The Mac has 4 internal 7200 HDD’s each 500GB.
    I’ve done a RAID 0 on 3 of the 4 drives.
    The remaining drive only hosts my OS and applications and the occasional desktop item drop.
    The 3 drives that were put into RAID 0 host all of my video & project files. This includes all of my raw video files, captured video & audio, video & audio previews, autosaves, file saves, and cache.
    Here is some of my thoughts:
    – I have a 1TB external USB drive that I’m thinking of using as a time machine backup because of the RAID 0, but the Mac only has USB 2.0.
    – If I do the time machine back up I’m thinking it would only be for the RAID drive.
    – Should I move the cache to the OS drive
    – Would a FireWire to USB connecter work to increase my external drive to speeds faster than USB 2.0
    – With FireWire 800 would an external drive be faster than an internal drive
    I have three 1TB USB 3.0 external hard drives and one 100GB USB 2.0 drive.
    Thank you!
    Rainer Wirth replied 11 years, 1 month ago 2 Members · 1 Reply
  • Rainer Wirth
    August 6, 2015 at 1:29 pm
    Hi James,
    Raid0 is no option. The problem with internal raids is the heat!
    Over the years it will burn your computer. So go for an external raid.
    13GB RAM? – no good
    – I have a 1TB external USB drive that I’m thinking of using as a time machine backup because of the RAID 0, but the Mac only has USB 2.0. – Good for back-up
    – Should I move the cache to the OS drive – possible
    – Would a FireWire to USB connecter work to increase my external drive to speeds faster than USB 2.0 – no
    – With FireWire 800 would an external drive be faster than an internal drive – no
    I have three 1TB USB 3.0 external hard drives and one 100GB USB 2.0 drive. – back-up
    What you need is an external Raid – at least esata with a minimum of Raid5 protection.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
