Activity › Forums › Apple Final Cut Pro Legacy › “Over recording” w Edit to Tape
  • “Over recording” w Edit to Tape
    Posted by Danastef on November 13, 2007 at 8:19 pm
    Hi Folks,
    As I “Edit to Tape” to a NDF SR Tape (as usual), I am over recording EXACTLY 5 seconds AFTER the length of my sequence.
    Do you’ll have any ideas?
    Mac Pro 10.4.10
    2.3 GHz Quad-Core Intel Xeon
    5 GB 667 MHz DDR2 FB-DIMM
    3 TB Serial ATA Internal Raid
    CS3 PS,ILL,AE / FCP 6.0.1 / QT 7.2.0
    SONY HDCAM SR srw-5000
    DeckLink HD Pro PCI-e
    Chris Borjis replied 18 years, 10 months ago 3 Members · 5 Replies
  • Chris Borjis
    November 13, 2007 at 9:55 pm
    check the mastering settings of your edit to tape window.
    the lower right side shows a checkbox with seconds you can fill in.
    I usually always leave it at 10 seconds though.
    You never know when or if a glitch might occur when it finishes and having that trail off prevents that.
    I realize with high end decks that very rarely if ever occurs, but its a nice safety precaution imo.
  • Arnie Schlissel
    November 13, 2007 at 11:08 pm
    Are you sure that it’s after the end of your sequence? You don’t, perchance, have an end-pop, or some other stray frame of media hanging out there?
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Danastef
    November 14, 2007 at 5:22 am
    Thanks Arnie and Boris,
    Yes, I am sure there is no stray frames, etc. (shift-z & when I’ve output – I’ve indicated IN and OUT marks for the sequence. The most egregious and obvious outcome of this OVERRECORDING occurs when I am insert editing amongst existing footage…and I “burn” into video and audio that is already on the tape.
    ie. In point on the Master Tape is 1:00:00:00 and I have a sequence that is 20 seconds long (and there is existing material at 1:00:22:00), Well, when I make the insert edit I am expecting it to go to 1:00:20:00…but it is going to 1:00:25:00…exactly 5:00 seconds longer than I want.
    This never happened with my G5 (non-Intel Mac…all the rest of the “rig” is the same).
    Thanks again for any insights you all have.
    Mac Pro 10.4.10
  • Danastef
    November 14, 2007 at 2:46 pm
    Awesome Borjs,
    That did it. The MASTER SETTINGS on the lower right (as you said)…someone must have changed that here…I don’t usually use MASTERING. I use EDITING.
    GREAT! Now back to frame accurate editing.
    Your idea of adding 10 seconds to the end so there’s a “clean out” is a good idea. I often times use slug at the tail of the sequence.
    Thanks again 🙂
    Mac Pro 10.4.10
  • Chris Borjis
    November 14, 2007 at 5:37 pm
    I always have to check if its on editing or mastering because you never know when someone is going to change it and not put it back.
    I almost over wrote some footage on a tape doing that.
