Activity Forums Apple Final Cut Pro Outputting to client monitoring in FCP X.. not yet
  • Outputting to client monitoring in FCP X.. not yet
    Posted by Vince Franke on March 23, 2012 at 12:55 pm
    Hello,
    I’ve used a Matrox MXO with FCP for many years outputting to a second monitor and a client monitor… worked great. I thought I’d be able to buy a MXO2 and still be able to output with FCP X, BUT in looking at the ins and outs in combination with my Late 2009 Imac, it doesn’t look to be possible…. AND my old MXO is not supported by the latest Matrox beta x.3.
    Any other solutions out there for outputting a signal to a second display? Expanding the canvas on a second monitor using FCP X is junk.
    Currently the plan is to wait for the next generation of Macs and Imacs and decide at that point, but who knows when that will be and I have clients coming over….
    Vince
    T. Payton replied 14 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bret Williams
    March 23, 2012 at 1:35 pm
    There really aren’t any viable solutions.
  • T. Payton
    March 24, 2012 at 4:57 am
    The Matrox drivers are definitely not a viable option at the moment. I have a MXO2 Mini and while it works, sorta, and can feed a HDMI Monitor as well as a CRT, it is defiantly beta and wouldn’t be usable with a client. However, I’ve heard much better reports from the Blackmagic and AJA broadcast drivers. But everything is still in beta, both FCP X broadcast monitoring as well as the drivers. BTW, you can pick up an Intensity Pro for about $200.
    Also, several months back I setup a workable client monitor setup. This might be helpful for your, or might not:
    https://www.fcp.co/forum/4-final-cut-pro-x-fcpx/1570-how-to-setting-up-a-client-monitor-in-fcp-x
    T. Payton
    OneCreative, Albuquerque
  • Eric Santiago
    March 25, 2012 at 7:22 am
    warning, Intensity Pro only works in Lion with FCPX 😛
  • Vince Franke
    March 26, 2012 at 8:27 pm
    Thanks for the thoughts and suggestions… Looks like I have sent myself down a FCP X dead end with going with a Late 2009 iMac. Doesn’t look like the Intensity Pro plays with an iMac.
    I’d love to hear any other options out there…
    Thanks again!
  • T. Payton
    March 26, 2012 at 10:37 pm
    Did you use the MXO with the 2009 iMac for a client monitor?
    T. Payton
  • Vince Franke
    March 29, 2012 at 12:17 pm
    Yes, I use the original MXO with my late 2009 Imac when editing in FCP 7. I have a mini display to DVI adapter on the imac so the MXO can send my image to a 23″ apple display and a 40 ” plasma (via component). I shoot mostly 720 and it looks great on both displays even with the component signal running to the plasma.
    The MXO does mirror the second monitor in FCP X, but to fill the frame on the second monitor FCP expands the image to 150% and so is totally soft.
    Hope this helps…
    Vince
  • T. Payton
    March 29, 2012 at 5:47 pm
    The original MXO is a very cool box. It sounds like your issue is that of the resolution setting for the MOX display. Couldn’t you just change it to 720p?
    T. Payton
