Activity Forums Apple Final Cut Pro Legacy Outputting the correct aspect Ratio 16×9 HELP 1440×1080=1920×1080???
  • Outputting the correct aspect Ratio 16×9 HELP 1440×1080=1920×1080???
    Posted by Tom Lee on February 24, 2009 at 5:38 am
    I’ve captured HDV 108060i footage into my project at 720p30 using the Apple ProRes 422 Compression. I then captured SD NTSC shot by someone else at 16×9 (or wide as some consumer cameras call it) in to my project at DV NTSC CCIR 601 using media manager to recompress with Apple ProRes 422 . I intended to place the SD footage in the sequence and conform the HD clips down to it to have full frame footage through-out (No pillars or bars) . After placing the clips I ultimately had to zoom in to all of them to conform to a 16×9 frame.
    Now when I export using compressor I cannot for the life of me get a final output with a 16×9 ratio. It seems to always, no matter what I change, come out as 720×480 with no pixel aspect correction. I have to open the clip in Quicktime and change the aspect ratio by typing it in after compression.
    Please somebody explain this square, rectangle, 1440×1080 is 1920×1080 corrected confusing mumboJumbo. I understand my Canon XH A1 at 1080160 produces a 1440x 1080 frame, after that, bringing it into FCP and out again, I’m lost. FCP doesn’t seem to reference 1440×1080 anywhere in the program. Why even tell me about 1440×1080, and not just make it 1920×1080. Just do the math back in some Mac closet and make everything standard. Did I mention I also regularly have to pull in AVCHD from my Sony HDR SR11. It has its own set of problems. Where can I learn somebody. please. Thannx.
    HELP
    Tom
    Noah Poole replied 17 years, 6 months ago 2 Members · 1 Reply
