Activity Forums Avid Media Composer Outputting media to tape without a mojo
  • Outputting media to tape without a mojo
    Posted by Dan Roland on July 20, 2009 at 9:34 am
    I am desperately trying to output Avid Media Composer V3.5 edited media to a Sony HVR 15AE tape deck from a media pc, but the signal is scrambled. I’ve heard this is a gen-lock problem or a sync-pulse problem. I have no mojo but have been told this should not be a problem – but what can I do? Capturing media into the system works fine, but outputting to the same deck or to a DVD recorder is not. Can anyone help at all?
    Dan
    Scott Cumbo replied 17 years, 2 months ago 2 Members · 6 Replies
  • Scott Cumbo
    July 20, 2009 at 4:03 pm
    I assume your going out firewire. do you have the avid and deck set to internal ref? are the input of the deck set correctly to firewire?
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Dan Roland
    July 20, 2009 at 4:30 pm
    Hi Scott,
    Thanks for the reply! Yes, they’re connected via firewire and internal ref is selected, so not sure what’s going on.
    D
  • Dan Roland
    July 20, 2009 at 4:53 pm
    Actually Scott, may be I don’t have the deck and the Avis set to internal ref – how would I do that, I don’t see an option?
    D
  • Scott Cumbo
    July 20, 2009 at 5:12 pm
    on the avid side you go to tools> video output tool.
    On the deck, i’m not sure. I’ve never used that deck before but i would just check the menu. or look it up in the manual.
    https://dl.owneriq.net/b/b96bd104-ab5a-4c49-bbb2-5a21d95642ea.pdf
    thats the manual with firewire info starting on page 32
    ALSO, are you sure the deck is in NTSC or Pal(if thats what your working in)? that deck is switchable between 50i and 60i.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Dan Roland
    July 21, 2009 at 2:29 pm
    Hi Scott,
    Thanks for that yes it was all in order. I have mucked around though with the player menu and somehow got it to work – all I have to do now is retrace my steps and work out what I did!
    Avid Media Composer Version 3.5 doesn’t recognise, or have in it’s deck settings, the Sony HVR-M15AE, which means Avid doesn’t talk to it very well when capturing or ouputting because I have to select another (different) HVR deck from the list – Dan
  • Scott Cumbo
    July 21, 2009 at 5:17 pm
    yeah Avid doesn’t always have all the flavors of firewire deck/camera templates. Most of the time the “General dv device” works fine.
    Glad everything worked out.
    Scott Cumbo
    Editor
    Broadway Video, NYC
