Activity Forums Apple Final Cut Pro Legacy outputting DNxHD from FCP 7
  • outputting DNxHD from FCP 7
    Posted by Sherril Schlesinger on June 23, 2011 at 10:55 pm
    I am trying to work with QT files that originated from AVID – DNxHD 1920 x 1080. I downloaded the codec package from AVID and installed it on my MacBookPro running OS 10.6.7. I then was able to import the files into FCP 7 and work with them with no issues. However when I try to export the files from FCP they don’t play correctly – they strobe and are out of sync! I have tried exporting with current settings and compressing to ProRes 422 but neither worked. The file is large – 174GB….does anyone have any ideas as to what I may be doing wrong and what the solution may be??
    Sherril
    Sherril Schlesinger replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
