Activity Forums Apple Final Cut Pro Legacy outputting and playing DVCPRO footage from the timeline
  • outputting and playing DVCPRO footage from the timeline
    Posted by Tim Silva on May 17, 2008 at 4:10 pm
    I’m pretty new to Final Cut Pro HD and am having trouble understanding some things. I’m having trouble outputting DVCPRO video from Final Cut.
    Importing footage seems to work fine. Video settings in and out all correspond to the DVCPRO 720p standards. But when we go to “Print to Video” I get a message that says “Conforming to HDV”. And why doesn’t the video play once it’s in the timeline? The screen says “unrendered”. In edit mode the clips can be played fine, but not from the timeline. What am I missing?
    Any help appreciated.
    Thanks – Tim
    Tim Silva replied 18 years, 3 months ago 2 Members · 2 Replies
  • Shane Ross
    May 17, 2008 at 4:30 pm
    Your sequence settings must be set to HDV…
    #28 Having to render every clip in the timeline
    Shane’s Stock Answer #28: When I put a clip in the timline, I have to render it before it will play. Why?
    Your clip settings MUST match your timeline settings. If you have DV/NTSC material, you need a DV/NTSC timeline. The frame rate, audio rate and dimensions (4:3, 16:9) all need to match exactly. In Final Cut Pro 6, this is easy, because when you drop a clip into the timeline, it asks if you want to set up the timeline to match the settings of the first clip you drag into it. Click YES and you are ready to go.
    However, in FCP 5.1 and earlier, it is a bit trickier.
    The most important thing you need to do is properly set up your project from the start, and the best way to do this is to choose a setting from the Easy Setups, located under the Final Cut Pro menu.
    Once you do this, you’ll need to create a new sequence. This is because the sequence that is already in your new project is setup for the typical default setting of DV/NTSC, or for the settings of your last project, which might not match what you are currently working with. So delete SEQUENCE 1 and create a new sequence:
    This new sequence will contain the settings you chose in the Easy Setup menu, and should match the format you captured.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Tim Silva
    May 17, 2008 at 5:31 pm
    Thanks so much. I’ll check on this Monday!. I’m not insane!
    Tim
