Activity Forums Blackmagic Design outputs on ATEM TVS
  • outputs on ATEM TVS
    Posted by James Corsolini on July 23, 2012 at 5:02 pm
    As I understand it, the only output from the ATEM TVS is SDI correct?
    No analog or component etc?
    Nothing seems to want to talk with the Black Magic stuff. I know it’s cheap, but if it does’t work with anything, what good is it?!
    Mike Squires replied 14 years, 2 months ago 3 Members · 2 Replies
  • Jeff Hartman
    July 23, 2012 at 7:06 pm
    The TVS has both SDI and HDMI outputs. The first is the industry standard for professional digital video and the second is something of a “pro-sumer” standard, as well as a common interface for monitors and projectors. So the TVS does in fact work just fine with an overwhelming majority of digital equipment out there.
    If your application requires analog outputs, perhaps an analog switcher would be a better fit than the TVS, which is fundamentally digital.
    — Jeff
  • Mike Squires
    July 24, 2012 at 2:33 am
    We have the TVS, and it outputs SDI and HDMI just fine. If you need analog output, go with the 1 ME or get a BMD converter (SDI to analog).
    Also remember, the TVS only accepts SDI or HDMI inputs, no analog, including audio.
