Activity › Forums › Apple Final Cut Pro Legacy › Outputing Windows Media on a Mac
  • Outputing Windows Media on a Mac
    Posted by Deathsultan on August 28, 2007 at 10:55 pm
    I have flip4mac $180 HD version, but I don’t have the option of outputing windows media via After Effect’s render engine.
    I know this isn’t a FCP topic, but FCP is a mac only app so I figured you guys would know how to encode for windows media…
    I want to be able to output to windows media from within the app(After Effects). How do I do this? Is this Possible? Is there an easier way to output Windows media?
    I have the FC Studio 2 and CS3 Student editon if that makes a difference. THANK YOU in advance!!!!!!!!
    Deathsultan replied 19 years, 1 month ago 3 Members · 6 Replies
  • Chris Borjis
    August 28, 2007 at 11:17 pm
    Do it on a PC is your only option.
  • Chris Borjis
    August 28, 2007 at 11:21 pm
    oops, looks like there is an option under File, Export
    but not from the render que.
  • Deathsultan
    August 29, 2007 at 12:59 am
    The thing that is frustrating is that I know that it is possible becuase I saw it on a G5 at my internship, but the person whose computer it was left the company and took the computer with her before I got a chance to get ask her….
  • Jeff Coleman
    August 29, 2007 at 2:18 pm
    Your version of Flip4Mac works as a plug-in for Compressor. I’m After Effects ignorant, but if you could render a file and load it to Compressor (say a hi-rez quicktime file) then it could compress a WMV movie. Settings/New Default Setting/Quicktime Export Components/Encoder Type: Windows Media
  • Chris Borjis
    August 29, 2007 at 3:11 pm
    I don’t understand.
    I just explained how you can do it.
    It won’t work from the render que, you have to
    do it from the file, export menu in after effects.
    I have the same version of Flip4mac that you have.
    It will work.
  • Deathsultan
    August 29, 2007 at 6:36 pm
    It works… but not good. So it basically doesnt’ work. The color is way off and the lines are not sharp.
    I will try with compressor…
