Activity › Forums › Apple Final Cut Pro Legacy › Outputing to TV
  • Outputing to TV
    Posted by Gracias on November 3, 2005 at 6:21 am
    Hello,
    My DV footage when I play from the Viewer and see it on the O/p monitor it doesn’t maintain the aspect ratio.(On TV monitor the image stretches vertically and and horizontally it sqeezes) But when the same is played from the sequences it play properly.
    I ve seen when I take 8bit footage with 25% compression it also does the same.
    I checked with my viewer, Square pixel is checked. Anything is missing
    Thankx
    Rody
    Kevin Monahan replied 20 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    November 3, 2005 at 8:43 am
    Is this footage 16×9 perhaps? If so, you need a monitor that can adjust for that…
  • Kevin Monahan
    November 3, 2005 at 8:03 pm
    A standard TV won’t have the option to squeeze the footage on the fly. A widescreen TV will though. This is why editors use pro video monitors and not TV sets. A proper pro monitor will squeeze your footage as it plays. Sounds like you need to break out some cash and get yourself some proper gear.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
