“Output To”
Hi there, I’ve around 150 comps that I want to batch render out. I have this all set up easily enough and I have made the comps into the filenames I want with a _v01 on the end. When I drag them into the render cue as a batch it’s all set up fine and so far so good. Then when I drag them in a second time I want the _v01 to become a _v02 and so on every time I render something new. The problem is that Ae seems to only want to add a _1 or _2 on the end of the _v01 so I end up with _v01_1, etc… Any ideas on how to set this up to do this properly in an incremental way that isn’t the Adobe standard?
Thanks in advance.
