Activity › Forums › Adobe Premiere Pro › Output to ProRes422 using Premiere Pro CS5 on a PC
Matthew Galvin replied 11 years, 9 months ago 16 Members · 22 Replies
Stephen Timpe
May 22, 2014 at 8:58 amThe above post by Terry tells you how to make a pro res file from within premiere pro… not sure why you are ignoring this as it works and i do it all the time. What you need to do is first pick Quicktime in the media encoder. Then, you want Custom, but will not have this choice until you go down to file formats and change it to yuv422 or h264. Then finish your settings, check aspect, your are good to go.
Matthew Galvin
November 25, 2014 at 6:01 pmCinemartin PLIN plugin is available for Premiere Pro and AE. You can also use FFMPEG, from the command line.
https://www.cinemartin.com/cinec/plin/
