Activity Forums Adobe After Effects Output to production monitor
  • Output to production monitor
    Posted by Yossarian on May 26, 2006 at 12:41 pm
    I often have color accuracy issues with my AE renders and have finally convinced the powers that be to grant me use of one of the extra production monitors around here. The question now is: What’s the most cost-effective way to output a signal to a production monitor while retaining color fidelity? Would a cheapo video card with S-video out do the trick, or should I step it up a bit? The goal is to keep the cost around $300 or less (and it would be ideal if I could get the same thing for two computers, but that’s not completely necessary).
    Thanks for your help.
    Danny Princz replied 20 years, 3 months ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    May 26, 2006 at 12:47 pm
    “Cheapo” and color accuracy generally don’t go together. S-Video is certainly better than composite, but nothing beats Component or SDI for true color accuracy.
    Are you running Mac or PC? On the Mac, if you’re trying to use this on two machines, I would recommend either the AJA Io LA or the Io LD depending on whether your monitor has SDI or Component inputs.
    Both are about $1,000 but they will give you full broadcast quality output to your monitors and it’s an external box so you can move it to whichever machine requires the output.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Mike Smith
    May 26, 2006 at 12:50 pm
    Aja good. Blackmagic’s Decklink cards can also do the job, and will also show both AE output and ColorFinesse output at broadcast quality. And they are a little cheaper.
  • Yossarian
    May 26, 2006 at 12:53 pm
    Thanks for the response. I’m working on PCs here, though; do you know of any decent cards for them or a place where I could look?
  • Walter Biscardi
    May 26, 2006 at 1:07 pm
    AJA.com AJA also makes a line of cards for the PC called the Xena.
  • Steve Roberts
    May 26, 2006 at 1:12 pm
    Blackmagic cards also work on PC. To see if there are any issues, check the Blackmagic COW.
  • Yossarian
    May 26, 2006 at 1:16 pm
    Thanks a lot for your help, guys. I’ll check into both of those companies.
  • Danny Princz
    May 26, 2006 at 1:56 pm
    been using decklink cards on my PCs for years for this purpose and they have been great, plus you cant beat the price
    who is that masked man…
