Activity › Forums › Adobe Premiere Pro › Output to monitor through MXO2
Posted by Rick Diamond on February 18, 2011 at 11:14 pmI’ve been using my MXO2 to output from Final Cut and After Effects with no problem. I know I’m probably missing something simple, but how do I get it to work in Premiere Pro? I’m using CS5.
Thank you,
Rick
Rick Diamond replied 15 years, 7 months ago 2 Members · 7 Replies -
Rick Diamond
February 19, 2011 at 12:51 amActually, I just tried to open another job and the Matrox presets are mysteriously missing. How can I find them?
Rick
Alex Gerulaitis
February 19, 2011 at 1:05 am[Rick Diamond] “Actually, I just tried to open another job and the Matrox presets are mysteriously missing. How can I find them?”
Can’t think of a reason it would. Have you tried restarting the system?
Alex
DV411 -
Rick Diamond
February 19, 2011 at 2:10 amYes, I restarted and also made sure that FCP wasn’t using the MXO2. Audio is being output through the MXO2 but not video. The Matrox folder is gone.
Alex Gerulaitis
February 22, 2011 at 12:15 am“The Matrox folder is gone” – containing presets? I would re-install Matrox utilities first and see if that fixed the problem; if you’d like to investigate this further, Matrox forums or Matrox tech support might be the way to go.
Alex
DV411 -
Rick Diamond
February 22, 2011 at 12:33 amThanks Alex. I downloaded the next version of PP and the Matrox sequence setting choices reappeared. The problem now though, is that the latest Matrox driver will work with PP but not with After Effects. I reloaded the previous Matrox driver and After Effects is once again OK, but the Matrox folder again disappeared from the sequence settings in Premiere. I’m on CS5 and I think that’s a problem for Matrox right now.
Rick
