Activity › Forums › Avid Media Composer › Output To Film from AVID Xpress Pro???
  • Output To Film from AVID Xpress Pro???
    Posted by Liam Stephens on January 30, 2006 at 8:41 pm
    Hi, The company i work for is about to lock picture on a feature film. Unfortunately no one here has any real experience with what needs to be done to get the locked film to the stage where we can cut negative. Does anyone know what we have to get done ie. EDL, FX Lists etc and the best way to go about it. Any help, info, points in the right direction or resources would be awesome.
    cheers
    Liam
    AVID Xpress Pro
    Michael Phillips replied 20 years, 8 months ago 2 Members · 1 Reply
  • Michael Phillips
    January 30, 2006 at 9:57 pm
    You would use FilmScribe to generate all the cutlists needed. From FilmScribe, open bin with final sequence/sequences and select list type and options for the metadata. Contact me at michael@24p.com if you need specific information or services for this process.
    Michael
