Activity Forums Apple Final Cut Pro Legacy Output to DV
  • Posted by Shaun Lavery on April 19, 2007 at 2:13 am
    Hey,
    Trying to output from sequence to DV deck. However,no picture is showing in the deck in the playback. Tried restarting and refreshing A/V devices, but still doesn’t show up. what other problems could be causing this?
    Vicky Weeks replied 19 years, 5 months ago 5 Members · 4 Replies
  • Jeremy Garchow
    April 19, 2007 at 2:22 am
    Hit control-q and chose your easy setup as DV NTSC or DV PAL.
    If this doesn’t work and you have recently upgraded a system from an older OS, try this:
    https://docs.info.apple.com/article.html?artnum=301852
    Jeremy
  • Walter Biscardi
    Do you an Easy Setup selected to match your DV settings? Either DV-NTSC or DV-PAL depending on where you are?
    External Video set to All Frames?
    DV Deck set to Firewire input?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Tim Vaughan
    April 19, 2007 at 11:42 am
    I have noticed in very unusual and extremely far between circumstances, sometimes you just have to restart FCP and the deck, and go in fresh. (Only happened once before….)
    However, do make sure all your settings are correct, or this will not help.
    Tim
    Tim
  • Vicky Weeks
    April 19, 2007 at 4:56 pm
    I’ve had the same issue as Tim at times, it is hard to ID why though. Sometimes, I’m not sure if I’ve done it before or after I’ve tried resarting (start deck first BTW) I do a “Print to Video” – even though I don’t really do the print, I just click OK in the dialog box, then cancel when the video screen appears, and FCP becomes aware of the deck. Sound’s like voodoo, I know….
    Vicky
