Activity Forums Avid Media Composer Output to Digibeta
  • Output to Digibeta
    Posted by Joshua Moise on April 5, 2007 at 8:04 pm
    Hello. I am outputting my Dv project to a digibeta from Avid Xpress DV and am wondering if anyone can tell me which quicktime codec is ideal? For example, should I export with the Animation codec or would the DV NTSC work just as well?
    Thanks in advance!
    Jon Zanone replied 19 years, 5 months ago 2 Members · 3 Replies
  • Jon Zanone
    April 6, 2007 at 11:24 am
    I’d use animation – you’ll generally get the most success with it.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Joshua Moise
    April 6, 2007 at 7:24 pm
    Thanks. Perhaps you can shed some light on something else; the project is 16:9. I exported a quicktime animation at 864×486 and plan to give the duplication house that file. Should I only export at 720×486 and somehow compensate?
    Josh
    Dell Dimension 9100
    Xpress DV
    AE 6.5
  • Jon Zanone
    April 7, 2007 at 12:39 pm
    No, I’d keep everything in it’s native size. If the project is 16:9, give it to them that way. Make sure they KNOW the project is 16:9, and if they need it at 4:3, they can easily reformat it.
    Jon
