Activity › Forums › Adobe Premiere Pro › Output thumbnails workflow?
  • Output thumbnails workflow?
    Posted by Ryan Hill on February 23, 2011 at 9:18 pm
    Any advice on a workflow for this?
    Say I want to pick one representative frame from each of a bunch of videos, and stick them as thumbnails into a single large image that I’ll print out. For each one, I’ll want some ID so I can find it again, probably the filename of the video, under the thumbnail of the single frame.
    I can easily export the images using “export frame,” and it names the image file according to the name of the video file. So maybe all I need is a way that will display all the images as an album or something, with their filenames below them? What would be a quick way to do that?
    Angelo Lorenzo replied 15 years, 7 months ago 2 Members · 3 Replies
  • Angelo Lorenzo
    February 27, 2011 at 4:28 am
    Do you have Adobe Bridge installed? Its output panel can create pdf proof sheets of thumbnails with filenames that are printer ready.
  • Ryan Hill
    February 27, 2011 at 11:42 pm
    Okay. I never really understood what Bridge was for, but it looks like it’ll do the trick. Thanks.
  • Angelo Lorenzo
    February 28, 2011 at 12:45 am
    Bridge is just that, kind of a bridge between assets and Adobe programs.
    You can use it for media management and organization. You can rate items, edit metadata, batch rename files, etc.
    It’s a pretty useful tool when your workflow starts expanding.
