Activity Forums Apple Final Cut Pro Legacy output settings to AJHD-1400
  • output settings to AJHD-1400
    Posted by Earle Nichol on June 28, 2007 at 3:58 am
    Hey gang, I’m new at this FCP thing, but have been dealing with HD for 4 years. I had a sequence today that was 720p 59.94 I let the AJA LH know this, The deck was set to record the same. I was going into the deck with embedded audio(I’m running FCP Studio 2 on a new G5) The tape was prestriped, and I would tell FCP I wanted to Assemble my edit to tape. Everything went fine except I could not get audio out..even though in e/e mode on the deck, I could see the audio going thru on a test run. What am I missing?
    Any hints would be greatly appreciated.
    pearl
    Earle Nichol replied 19 years, 2 months ago 2 Members · 2 Replies
  • Dream Master
    June 28, 2007 at 7:27 pm
    Ensure your Audio output is set to firewire and not built-in or something else. It’s at the bottom of the edit menu.
  • Earle Nichol
    June 29, 2007 at 3:31 am
    Thanks,but I’m going out HDSDI thru the AJA into the AJHD-1400 embeded audio…so is there someplace in the output settings to tell it that? I talked to AJA and they said all BNC spigots are active all the time,…. so why is the audio not gettng out on output?? Deck settings semm to be correct
    pearl
