Output Resolution
Hi
I am using Adobe Premiere Pro 2.0. When I view the captured video in the viewing panel the resolution is crisp and clear. After I drag the video in the time line and review it in the playback panel it looks like it lost from quality. Even worse, when I burn a DVD and play it on TV (any TV) it has vertical lines (low resolution). I assume it has something to do with the output resolution but where do I change that? Please help me!
Thank you
Adriana
