Activity Forums Apple Final Cut Pro Legacy Output level
  • Posted by Darryl Thomson on July 17, 2008 at 4:21 pm
    In Final Cut rather than Soundtrack is there a way of adjusting the overall level of the left and right output tracks/faders.
    If you use the track mixer it seems to only apply to the particular audio segment the time line is at. I’m looking for something more global. It would be called the output bus in and audio editing or music program. Is such an option available?
    Dazzer
    FCP 6.0.4
    Paul Dickin replied 18 years, 1 month ago 2 Members · 1 Reply
  • Paul Dickin
    July 17, 2008 at 5:44 pm
    Hi
    Select the full length of the track in the timeline, then in the Modify Menu choose Audio – you can then adjust the Gain of all the selected clips in either 1 or 3dB steps, + or -.
    There are keyboard shortcuts to speed the process.
