Activity Forums Adobe After Effects Output from AE to Vegas, best format
  • Output from AE to Vegas, best format
    Posted by Kevin Labonty on October 28, 2006 at 11:36 pm
    What is the best format (.mov, .avi, etc…) and standard codec to output from After Effects to Vegas? Is there a format I should be using to keep good quality video and reduce render time?
    Aharon Rabinowitz replied 19 years, 11 months ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    October 30, 2006 at 11:27 pm
    Generally, one of the best options for pro-quality and smaller file size is Quicktime Animation Compression. I output everything that way. Quicktime with animation compression is a lossless compression format.
    Speed wise – as far as Renders go, I don’t know if there’s a difference. However, A video file (as opposed to an image sequence) will work faster in most NLE’s.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Aharon Rabinowitz
    October 30, 2006 at 11:29 pm
    bTW – by smaller, I mean smaller than an uncompressed AVI. those things are 1.75 GB per minute. depending on what you’ve got in your video, you could save a lotr of space with animation compression. But not compared to a quicktime with sorenson compression – which is a lossy compression format, and which (like all compressed video files) takes a lot longer to render because it is rendering and compressing at the same time.
    Aharon Rabinowitz
