Activity Forums Adobe Premiere Pro Output DVD has square box around it – shrunk picture
  • Output DVD has square box around it – shrunk picture
    Posted by Joseph Hankerton on November 18, 2008 at 5:58 pm
    Honey, I’ve shrunk the picture!
    Can someone help me with something basic here.
    I am trying to burn a dvd from my clip but when I watch it on a standard TV the picture has shrunk and there is black border all the way around the image.
    My clip setting is 720×480, 29.97
    I used adobe media encoder to export to mpeg2 with the same settings as above (I just take the defaults) and:
    Pixel Aspect Ratio: Standard 4:3
    I then take this mpeg and use the app ‘dvd flick’ to burn this mpeg file onto dvd. The dvd flick setting is also 4:3 – so it is set to play on normal tv’s
    Then when I play it on my TV it looks like the image has shrunk down to a smaller size.
    I don’t have adobe encore which would be the normal route.
    Any ideas?
    Joseph
    Adobe Premiere CS3
    PC
    Prateek Jitendra replied 17 years, 9 months ago 3 Members · 2 Replies
  • Eddie Lotter
    November 18, 2008 at 7:15 pm
    [Joseph Hankerton] “Pixel Aspect Ratio: Standard 4:3”
    That’s not a pixel aspect ratio. 😉
    See: FAQ:Why are there black borders/bars?
    Cheers
    Eddie
  • Prateek Jitendra
    November 27, 2008 at 8:41 am
    hi joseph,
    the settings you have used for exporting looks fine. however, what was the project setting which you had taken ? For the work flow that you are trying, you need to take a NTSC STD project. you can also try one more thing to narrow down the problem. try playing back the AME output and see if this output has got those black-borders. If no, then this could be a bug in the application you are using for burning the DVD.
    thanks,
    Prateek
