Activity Forums Apple Final Cut Pro Legacy Output codec for Flash re-encoding?
  • Output codec for Flash re-encoding?
    Posted by Phillip Van west on April 5, 2006 at 12:01 am
    I have a short (3 min) movie that I need to give to someone else so that he can encode it with the “On2 VP6” codec for web use.
    I have the Sorenson Squeeze suite but not the plug-in for that codec. He has Flash 8 and can make the movie with that codec.
    My question is: What compression scheme should I use for the file I give him? I WOULD simply give him an uncompressed .mov
    but it’s 7.2 GB and I need to get it to him on one DVD (just for the file transfer) since he doesn’t use a Mac, so I can’t span it over 2
    discs with Toast as I normally would.
    Any educated advice? Thanks very much in advance.
    pvw
    Phil Van West
    Terra Nova Productions LLC
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.4.4 / FCP 5.0.4 / QT 7.0.4
    Stevec replied 20 years, 5 months ago 3 Members · 3 Replies
  • David Roth weiss
    April 5, 2006 at 1:36 am
    Phil,
    Certainly delivering in an uncompressed format would be best, but since you can’t, give him a QT with photo JPEG compression. Its a very high quality lossless compression scheme that yields very much smaller files than uncompressed. Flash 8 with the On2 VP6 codec is pretty awesome and will make great stuff that pretty much matches the original in terms of quality, but the files are small and fast loading.
    DRW
  • Phillip Van west
    April 5, 2006 at 3:18 am
    Thanks, David, for that quick response. I’ll give it a try.
    pvw
    Phil Van West
    Denver, CO
    G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.4.6 / FCP 5.0.4 / QT 7.0.4
  • Stevec
    April 5, 2006 at 4:07 pm
    You could also burn the uncompressed file to a double layer DVD, assuming he has a DVD player that can read a DL DVD.
    Steve
