Activity Forums Apple Final Cut Pro Legacy Output Audio Split Track to 4 tracks of Digibeta, Would be direct out on Avid
  • Output Audio Split Track to 4 tracks of Digibeta, Would be direct out on Avid
    Posted by Jaybee on February 9, 2007 at 9:32 pm
    I am running FCP 5.1 with a Kona LH breakout box. Trying to output 4 tracks of audio from the time line to the corresponding tracks of the Beta deck. Currently I can’t get 4 tracks of audio to the beta, I’m trying to go embedded over the SDI cable, but I’m only getting two. And they are merging together(going stereo) on the output.
    I have to deliver the program today, and I didn’t forsee this being a seeming impossibility.
    Eric replied 19 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    February 9, 2007 at 9:47 pm
    The Kona LH cannot output more than two tracks of balances audio. It can do 4 tracks via SDI, but…what beta deck accepts SDI? I know digibeta decks do.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Shane Ross
    February 9, 2007 at 9:53 pm
    AH…you need to tell the audio where to go.
    So you have your timeline…with it active, press APPLE-0 (zero). Click on the AUDIO OPTIONS tab…far right. There you can set the number of outputs to 4, and map what goes where.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Eric
    February 12, 2007 at 11:15 am
    Also: In Video-Settings/ Device Control > Set Audio channels to 4
    The Kona defaults to 2 AFAIK
    Uncheck downmix in the audio mixer window
