Activity Forums Apple Final Cut Pro Legacy Output 10 Bit to Mini Dv
  • Output 10 Bit to Mini Dv
    Posted by Rizwan Saeed on January 24, 2011 at 3:21 pm
    Hi All,
    I am trying to output a 10 bit uncompressed FCP timeline to a Mini DV tape for broadcast. I wanted to know what is the way the get the best qaulity results. Do I use SDI or Component? Is it possible to connect my laptop with a blackmagik SDI External Card to output without losing quality?
    thanks,
    Rizwan
    Rizwan Saeed replied 15 years, 7 months ago 4 Members · 4 Replies
  • Walter Soyka
    January 24, 2011 at 3:51 pm
    [Rizwan Saeed] “I am trying to output a 10 bit uncompressed FCP timeline to a Mini DV tape for broadcast. I wanted to know what is the way the get the best qaulity results. Do I use SDI or Component? Is it possible to connect my laptop with a blackmagik SDI External Card to output without losing quality?”
    MiniDV is a highly-compressed 8-bit 4:1:1 (or 4:2:0, depending on your region) format.
    Could you use DigiBeta instead?>
    Walter Soyka
  • Rafael Amador
    January 24, 2011 at 4:30 pm
    No need of any hardware. Transcode the movie to DV and print to tape.
    rafael.
    http://www.nagavideo.com
  • Jeff Greenberg
    January 24, 2011 at 4:56 pm
    [Rizwan Saeed] “Do I use SDI or Component?”
    If your DV deck had both of these connections (it’d have to be DVCPro25 or DVCAM), I’d go SDI over component.
    [Rizwan Saeed] “Is it possible to connect my laptop with a blackmagik SDI External Card to output without losing quality?
    Nope. No internal cards can go on a laptop. AJA and matrox both make devices for output from a laptop.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Rizwan Saeed
    March 1, 2011 at 1:45 pm
    Thanks a lot
